Ana içeriğe geç
Sony Camera model number A5000, released Jan 7, 2014.
3 Soru Tümünü görüntüle
Lens says it's not attached properly
There's a message on my camera saying "cannot recognize lens attach lens properly" it's perfectly attached so I'm not sure what's wrong.
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Your lens is probably damaged. Check the connections on the back of the lens . make sure they are not corroded
You may be able to clean the contacts with an eraser.
Good luck.
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
Wnen I said "damaged" what I really meant was, the contacts were likely dirty or corroded. My fix still works, but you can also use denatured alcohol and or Deoxit if they are really bad
tarafından
Yorum Ekle
Yanıtını ekle
Anabelle Trujillo sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 1,110
