Ana içeriğe geç
Screen discoloration in top right corner of iPhone 6 Plus, please help
I replaced the front panel on an iPhone 6 Plus last night. I tested the LCD before installing all of the components (front camera, speakers, home button, etc.) into it, and it seemed to work fine. I even did one more test run before I closed the screen to make sure all of the cables were connected well, and it worked perfectly. When I closed the screen, however, a bright spot had appeared in the top right quarter of the phone. I have had two other 6 pluses with identically shaped and positioned bright spots, so something I am doing wrong must be causing this. Please help me with any information you know.
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
It would be helpful if you posted a picture (you can add it to your question).
Generally speaking, white spots are caused by pressure. So if you have a bright spot in the top right corner, look at the camera and screen bracket area for something that isn't installed or lined up properly. It could also be a batch of poor quality screens where there is some dust or something else sandwiched between the LCD and backplate (this would be a very small white spot though).
Bu yanıt yardımcı oldu mu?
Puan 4
1 Yorum:
I had a white spot also. It was the battery pertruding slightly on the upper left edge (original battery and screen). I solved it by lightly pressing down the edge of the battery with the flat end of a plastic spudger.
tarafından
Yorum Ekle
i think it has no solution take it to apple authorized centre
Puan -1
Yorum Ekle
Yanıtını ekle
Garrison Bates sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 6,108
