Ana içeriğe geç
Repair and disassembly guides for Epson printer. The company was founded in 1942 as Daiwa Kogyo, Ltd., but merged with another company in 1959 to create Suwa Seikosha Co., Ltd.
epson l360 cant print legal paper
i'm trying to print some projects that requires a legal size paper. how ever epson l360 only prints in a4 or letter size paper. i tried to customize everything but still does not work. what should i do to print my project in legal size paper?
Bu iyi bir soru mu?
Puan 31
9 Yorum
I looked around online (as I'm sure you did too) but didn't find anything promising. If the printer doesn't accept legal size paper it may not be (reasonably) possible to force it.
(I say reasonably because I'm sure there are all manor of Unreasonable ways we could try to do it. Changing the firmware/code is totally beyond me. And folding the paper to make it fit and changing the document accordingly would be asking for trouble. Plus it would work badly, if at all. Then you'd be troubleshooting a paper jam as well.)
Best of luck and I hope someone else has something better to suggest.
tarafından
We cannot detect the epson printer
tarafından
I have my problem. My printer is epson L360 .. now im printing a email and printer isa just printing half of the email lower part of the paper is blank .. how to solve this ? Please help me
tarafından
How do scanner legal print l565
tarafından
I cannot print legal on my Epson L210 printer, any solution? thanks
tarafından
4 tane daha yorum göster
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
go to www.epson.com.ph then click SUPPORT>PRINTER>INK TANK PRINTERS> L SERIES> Epson L360 > operating system dectected> DRIVERS> then installed any or both if applicable the Printer Driver for WIN 64 bit and Scanner Driver for winndows> restart your PC. DONE.
Bu yanıt yardımcı oldu mu?
Puan 48
39 Yorum:
Thank you! Problem solved!
tarafından
tarafından
been stressed for a week finding out a solution, i knew it!!! thanks to you. Godbless
tarafından
it works!
Thank you very much God bless
tarafından
how to print legal size on epson L360?
tarafından
34 tane daha yorum göster
Yorum Ekle
Solved! (for me)
I have the same problem, I am using windows 10 and by then, the printer is using the default driver within the OS, thus, it recognized upon plug and play. I have configured the paper size to 8.5" by 13" but sill it prints in A4.
Solution: I located the mini DVD driver that came with the printed, installed it and then it solved the problem.
Puan 2
3 Yorum:
thank you very much... great help indeed
tarafından
What if the dvd driver is lost?
tarafından
Well, that works... Thank you so much!!!
tarafından
Yorum Ekle
Go to control panel→Hardware and Sound→device printers→open the properties of epson l360→advanced→change the driver to EPSON L360 SERIES..
Puan 0
Yorum Ekle
Yanıtını ekle
Junape sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 61
Son 30 gün: 337
Her zaman: 82,531
