Ana içeriğe geç
Overheating Television With Smoke
I heard a small pop in the back of the tv then white smoke and a burning smell came from the tv.
Update (07/30/2017)
Resim
Resim
Resim
Resim
Images, Model, and Board where smoke is coming from.
Update (07/30/2017)
Resim
Resim
Plugged it in with the back off, the smoke is coming from burning on the board about 6 inches above the power supply.
Bu iyi bir soru mu?
Puan 1
7 Yorum
Your tv gets a short-circuit on the motherboard.
tarafından
Smoke was coming out my TV, it still works perfectly. The only problem is that the sound starts to crack after a short time of watching something
tarafından
I have a 39 in Visio TV
tarafından
I have the same problem of smoke and small water that cames out to my tv the name is Muller&haupt tv the time I so the smoke I did switch it off sametiy what could be the problem
tarafından
The same thing happened to my sinotech while is off but the generator was running so I just see a smoke at the back of the TV and the decoder as well
tarafından
2 tane daha yorum göster
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
@knarf1 well sounds like one or a couple of components went up in smoke. Unplug the set and do not use it until you identified the issue. Let us know exactly what model your TV is. Remove the back of your set and take a close look at the boards to see if you can identify which component(s) have gone up in smoke. Post some good images with your question so we can see what you see. Use this guide for that.
Update (07/30/2017)
Looks like multiple failure here.
Resim
Burned capacitor and possibly bad IC. You can either replace the complete power board or try to find a schematic to replace the individual parts. We still do not know what model your TV is. Repalcement power supply is available at places like this and many more.
Genuine Samsung component for 51 CLASS Plasma TV models, addressing power-related issues. Görseli
Ürün
BN44-00599A - Samsung DC VSS-Power Supply Board
$239.99
Bu yanıt yardımcı oldu mu?
Puan 2
6 Yorum:
Today o experienced the same issue with armaco tv...i just bought it yesterday and now it has produce a pop sound with white smoke... .but after reconnecting its still working normaly
tarafından
Ours is an insignia smart LED tv. It just arrived now and the back began to smoke when we plugged it in to the wall socket
tarafından
I experienced same issue this morning with via low current issue. I run to my living smoke popped up smoke with smell of burn but I haven’t reconnected it what should I do pls
tarafından
@josephfran68098
Disconnect the power to the TV, remove the back cover from the TV and then check the boards for any sign of damage i.e. burnt out components.
Post some images of what you find back here in a new question on ifixit. Don't forget to add the make and model number information if you do.
tarafından
Mine just did the exact same thing ! I heard a little like pop/hissing sound and I look up to see smoke protruding from my ONN(Walmart) tv!!! I’ve had it for over 5 years now and only paid about $230 for it- so technically I should just replace it…. Right!?🫣
tarafından
1 tane daha yorum göster
Yorum Ekle
For everyone's reference, a POP with WHITE smoke is most always a capacitor. It might be a small one or an electrolytic
The pictured problem is probably a bad transistor/SCR/MOSFET and it looks like a capacitor associated with it. However, the black burn marks could be coming out of that thru hole where the heat sink is attached and be a result of a bad solder joint.
No telling how many components were damaged.
The failure might have been created by another problem elsewhere.
If you have a DVM and enough expertise to check components on the board or remove them and check them and find a definite bad part, it may be fixable. Remove the bad parts. Clean up all the black stuff - it creates resistance shorts.
Replace parts and try again. Or just replace the board. If you can find service info, it is best to verify there is no problem on another board that lead to this.
Puan 0
Yorum Ekle
Yanıtını ekle
Frank sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 27
Son 30 gün: 170
Her zaman: 44,916
