Will not power on
Will not power on. Checked all ribbons already. Also battery status button on bottom mot working.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Not sure if your problem is the same as mine, but I am having the same issue as you are. After taking it apart the only thing I noticed was the bus ribbon cable that runs from the PCB board at the top of the keyboard and mounts around the power button and connects to the main board had the contacts coming off so they were not connecting properly. I have been unable to locate that specific ribbon cable so far other than from Ali express which makes me nervous. However most of the things I’ve read that says if the computer doesn’t power on to check this cable. Good luck and I hope you find a solution.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 2
Her zaman: 264
Have you tried turning it on when its plugged in?
Cameron tarafından
