How to check u2 before replace
hi the team
can you help me please
I have an iphone 6 with problem u2
How should i do u2 test before changing it
Be sure it is damaged
I have power supply
Thinks the team
Bu iyi bir soru mu?
hi the team
I have power supply
Thinks the team
Bu iyi bir soru mu?
There is no magic bullet when testing for a Tristar (U2) issue. Tristar is responsible for communicating with any device plugged into the Lightning port. Here are some suggestions to help you determine if U2 is the problem:
Here is a good blog post on U2 symptoms.
N'hésite pas à continuer de poser des questions, c'est de cette façon qu'on apprend!
Bu yanıt yardımcı oldu mu?
thinks bro minho good job
I am very grateful to you
https://www.youtube.com/watch?v=JTDLAMso...
I can take this video into account MINHO
bro does the iphone 6 work without u2 ic ? its required for working ?
My iPhone stopped recognizing by iTunes. Should I change the u2?
U2 ic work tell me my phone is stuck on itune so guys tell me how softwere on pc .
When I started in mother board repair, we would wonder a lot about this exact question.
- OK so everything before seems to be working properly.
- We have the right symptoms.
- Yet we are not confident enough in our micro-soldering and micro-BGA skills, so we really want to be sure before attempting to replace it.
- Here's the spoiler: there is no real fool proof method to rule it out until you.. replace it. This is the single most efficient way to trouble shoot it. If you are good at it, it should take 5 minutes to remove, clean pads, install new one. 20-25 minutes from lifting screen to reassembling last screw.
- Bonus point: Tristar chips (which you call U2, but should really call Tristar if you want to sound professional) are sort of consumable parts of an iPhone board. They "deteriorate" as you use them specially from power spikes, fake chargers, fake cables, poor quality car chargers, lightning accessories. They are cheap too. So if you suspect them, it is always good to replace them. You can only do good for the device and the trouble shooting process.
- Common Tristar symptoms: not recognized by computer; not charging; charging slowly; booting from charged battery but unable to charge a flat battery.
thinks bro RANY
thinks
There are components near U2 IC that tells the voltage they have when phone is powered on, meaning test them with battery and phone powered up. You can see in the schematics the value, 5v and 1.8. if the result value is lower than that then its time to change the U2.
br
-Mike
You're right my friend I saw her on ZWX
But I got better answer by you three
Could it also be the components aground the u2 chip? Or it doesn't affect the u2 when some of the components are faulty?
Son 24 Saat: 3
Son 7 gün: 15
Son 30 gün: 49
Her zaman: 60,882
3 Yorum
RESOLVED thinks FRIEND
Mike Plouvin tarafından
me too thats my problem not solve
renie tarafından
There's a device called a TriStar tester about $120 online, a little blue device with a lightening port sticking out of it, you make sure no dust/lint/debrees are caked in the bottom of the charging port then turn on the TriStar tester and plug it into the lightening port of the iPhone or iPad, after this hit test it will first make sure all power and data lines in the charging port are functional, secondly it tests that the battery is present, and thirdly it tests all 9 TriStar/Hydra lines and let you know if it's alright, totally failed, or partially failed. Unfortunately the only time this is convenient is for shops that replace tristars like the one I work at, call around your local shops ask if they can test it for you the whole process takes about 1.5 minutes.
Owen M tarafından
