Ana içeriğe geç
Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2375 Soru Tümünü görüntüle
Can not enter apple id because of dead spots
I have two questions...First I can't turn or toggle off my " Find My Phone " because I can't enter my Apple ID due to dead spots where the little globe is....
How do you think I can disengage the find my phone on the device. I tried on iCloud.com and there doesn't seem to be a place to do it.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
If you log back into iCloud.com and go back to find my iPhone, you are going to look for "devices" and click on it. Find your iPhone, click on it, then click "remove from account"
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
En Yararlı Yanıt
See if you can turn it one its side or invert it to move the area.
Puan 3
2 Yorum:
Thank you @mayer for your response. I have turned the phone horizontally for most sites which as you say allows me to tap on a different spot ( not so dead...hahaha ) When it comes to entering my Apple ID however the phone does not turn. Because it won't turn horizontally I can't tap a little different spot where the globe is which would allow me to use the numbers. Numbers are part of my Apple ID.
When you suggest inverting the phone, we are talking about the same thing ....right? When you say invert you're just using a different word for horizontal? Unless invert means something else??
tarafından
in·vert
verb
inˈvərt/Submit
1.
put upside down or in the opposite position, order, or arrangement.
"invert the mousse onto a serving plate"
synonyms: turn upside down, upend, upturn, turn around/about, turn inside out, turn back to front, transpose, reverse, flip (over)
tarafından
Yorum Ekle
Yanıtını ekle
Victoria Chandler sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 2
Son 30 gün: 2
Her zaman: 70
