Ana içeriğe geç
A USB car charger much like any other.
2 Soru Tümünü görüntüle
Can I include a fuse in the generic USB car charger?
Bought a generic USB car charger. Can I just purchase one and include it in the charger? If so what amperage?
Bu iyi bir soru mu?
Puan 0
1 Yorum
I originally had the pink one which came with a fuse similar to what is pictured. However the fuse was lost because the tip of the charger was removed and it popped out. I bought the white one which came without a fuse. My question is what amperage fuse should I get to replace the lost fuse? The second question was if I could add a fuse to the white one as a safety measure,bearing in mind the fuse is simply inserted into the top of the charger.
[image|1173438]
[image|1173436]
[image|1173435]
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
The car charger was either designed to take a fuse or it was not.
If it isn't, you can't easily add one unless you take it all apart and modify it yourself (if it is even possible at all).
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Kevin Thompson sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 425
