Ana içeriğe geç
7.9 inch display / Model A1432 / Available in black or white / Announced October 23rd, 2012 / 16, 32, or 64 GB capacity
volume button not working
The top of the two volume buttons is stuck and doesn't work.
Are the buttons replaceable ?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Yes, you can replace the buttons or the button flex (or both if necessary). It will require that you remove the glass/digitizer to access the inside. The iPad mini is one of the more difficult tablets to repair and there are lots of "gotcha's" when re-assembling (which is not covered in the guides).
I would start by looking through the repair guide first. There is no Volume Button guide for the iPad mini but the Logic Board guide will show you how the mini is assembled and the iPad Air Volume Button guide will show you how the button flex is installed (it uses the same flex as the mini).
Take note of what tools and parts you need and then determine if this is something you want to do yourself. Otherwise, look for a repair shop that has a lot of experience with iPad mini's .
Fix an unresponsive power or audio button by replacing the internal switches with this cable assembly. Görseli
Ürün
iPad Air and iPad mini Volume and Power Button Cable
$14.99
iPad Mini Wi-Fi Logic Board Görseli
Kılavuz
iPad Mini Wi-Fi Logic Board Replacement
Zorluk:
Çok zor
1 - 3 hours
iPad Air Wi-Fi Case Button/Cable Görseli
Kılavuz
iPad Air Wi-Fi Case Button/Cable Replacement
Zorluk:
Zor
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Yanıtını ekle
Morgan Mark sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 3,329
