Battery problem in Braun electric toothbrush 3D D 15511
Can this can be repaired
Bu iyi bir soru mu?
Bu iyi bir soru mu?
In theory yes, in practice...that depends. I have a similar model that failed and I opened it up to see if I could just replace the battery, The problem was everything was corroded to near death inside. The battery is not designed for easy replacement and everything is soldered in place. I found the defective components and was able to order them (IC's & Battery) but the logic board was in very bad shape.
So I would certainly try, otherwise the tooth brush will just end up in the trash. Hopefully you'll have better luck than I did.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 8
Her zaman: 126
