Ana içeriğe geç
This is a standard irrigation system control box used for residential homes. It can manage a maximum of six valves.
Not getting any power to the unit.
After returning from a trip, I discovered I had a blank screen and there is no power to the unit.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
1 Yorum:
My Rain Bird ESP- 6TM's screen says "PR OFF", while there is power in my wall outlet. Not any button on the controller now works. I checked the fuse, the fuse is good. I removed the lithium battery, the "PR OFF" went away, I put the battery back in, the "PR OFF" came back. Can anybody tell me what else to check and how to fix the problem? Thanks.
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
REF: http://www.rainbird.com/documents/turf/m...
Have you checked the breaker? The wall outlet?
If power is at the wall outlet, then you can use a multi-meter to check power at the end of the power supply cord at the (24VAC) terminals inside the control panel - see Page 34. This link gives you the part numbers in case you need to replace: http://www.rainbird.com/documents/parts/...
Also, check out the troubleshooting guide on page 36.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
My unit has a reset button the back of the door. I now have readings again!
Puan 0
Yorum Ekle
Yanıtını ekle
Larry sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 23
Son 30 gün: 66
Her zaman: 17,421
