red lines across display
after replacing the digitiser on my Ipad3 (A1699) red and grey alternate lines appeared on the display. screen is otherwise unresponsive
Bu iyi bir soru mu?
Bu iyi bir soru mu?
You may have damaged the LCD while repairing the digitizer. I would go back through your steps to see if anything is obviously wrong and also double-check your connections. The LCD is surprisingly fragile if you touch apply any pointed pressure along the edges.
Bu yanıt yardımcı oldu mu?
Many thanks for the information
If you found this answer helpful, please select "Was this answer helpful? - YES" and/or if this answer solved your problem, please “Choose as Solution”. This allows people in the future to understand which answers helped solve the problem and adds value to the site. - Thanks
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 5
Her zaman: 317
