Ana içeriğe geç
Charge indicator LED permantly on
I have an Alcatel One Touch 4015X (I believe its commonly know as a Pop C1) that maintains the charging indicator LED permanently on.
This started after replacing the original battery. After two charging cycles , the phone stopped receiving charge and the charging indicator LED will no go off.. When connected to a charger, it indicates it is charging but it actually consumes more energy, spending about 5% to 8% battery every 10 minutes.
The battery is an official Alcatel replacement part.
I tried replacing the original battery but the problem persists.
There is no apparent damage to the charging port.
I have tried another charger, with no success.
Connecting the phone to the computer allows me to access all USB functions but even if set to charging mode, no charge goes to the battery.
Bu iyi bir soru mu?
Puan 0
1 Yorum
Are you that "charging mode" isn't supplying power instead of charging itself?
tarafından
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
Battery's bunk. Get a new or replacement one from where you got bunk one
Bu yanıt yardımcı oldu mu?
Puan 3
7 Yorum:
Reverted to the original battery and the problem persisted.
I only got the replacement because its life time was getting very low, about 3 to 4 hours long on stand by.
tarafından
So you still don't have a known good one? If the battery isn't the issue then it's the charging circuit. We may have a guy here for that
tarafından
I was able to get the new battery tested on another phone that uses the exact same battery model and in that phone the battery took up charge so yes, the problem may reside in the charging circuit.
How can I get a hold on the person in question?
tarafından
@refectio they've requested an audience with your awesomeness!
tarafından
Thanks.
I'll drop the guy a line.
tarafından
2 tane daha yorum göster
Yorum Ekle
Install this app, charge it a few times and check your battery health:
https://play.google.com/store/apps/detai...
Then tell us what it says.
Puan 1
2 Yorum:
I'll do this as soon as I can and post back some data.
tarafından
The phone is too old and is not supported by the app.
Thanks for the thought, tho.
tarafından
Yorum Ekle
Try to change the battery
Puan -1
1 Yorum:
Again? The original only got replaced because it was getting very short lived, even on stand by, and after reverting back to it, the problem persisted.
tarafından
Yorum Ekle
Yanıtını ekle
Qyron sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 7
Her zaman: 1,850
