Ana içeriğe geç
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Soru Tümünü görüntüle
Branson EC not available in Europe... What to buy
Hi I'm looking for a product similar as Branson EC for cleaning pcb's with an ultrasonic cleaner. The product Branson EC is not available in EU. So what should i buy?
Bu iyi bir soru mu?
Puan 3
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
@idoc Here you go for Belgium (I used it and it works very good)
Bu yanıt yardımcı oldu mu?
Puan 2
2 Yorum:
Thx, so do you use it in combination with distilled water?
tarafından
yes, with distilled water. 400 ml of Es132 for almost 4 liters of water
tarafından
Yorum Ekle
En Yararlı Yanıt
You could look into the Chemtronics Flux-Off Aqueous. There is some chatter about it on some of the rework forums. I haven't used it myself so I can't say with certainty. I did look at the spec sheet and it is definitely made for cleaning electronics (flux). That is the primary mission of Branson EC as well.
I also read that Branson has an office in the Netherlands (perhaps elsewhere in Europe too). I would reach out to them to see if the EC solution is available or not.
Puan 5
7 Yorum:
Same problem, shipping to Belgium is not possible. Wil try to contact the company in the Netherlands
tarafından
That's the one I use , you can find it on mouser.com
tarafından
@soros
Salut Oros. En tant que contributeur chevronné sur ce site, tu devrais commencer à voter plus souvent et t’impliquer dans la modération. C’est le seul mécanisme qui permet aux bonnes réponses de se hisser au sommet et d’y rester.
Cela peut sembler inutile lorsqu’il y a seulement une ou deux réponses, mais avec le temps, ces questions seront inondées de réponse loufoque, répétitives et parfois fausses. Quand personne ne vote, ça prend juste un ou deux mauvais votes pour sacré le bordel :>).
Tu as les qualifications nécessaires pour t’assurer que les bonnes réponses soient récompensées et bien vues par les autres. Cette réponse est un parfait exemple. Tu es d’accord avec ma recommandation, mais tu ne votes pas.
La grande majorité des votes sur ce site sont donnés par les autres contributeurs réguliers. Sans ces actions, ce site n’aurait que très peu de valeur.
tarafından
@soros
Merci encore pour ton activité sur le forum. J’espère que tu continueras de t’impliquer davantage.
tarafından
@refectio Merci pour m'avoir précisé ca. je comprend bien ta remarque. Je me suis axée plus sur les questions sans réponse et je un peu ignorée celles avec un ou deux reponses...
tarafından
2 tane daha yorum göster
Yorum Ekle
Buy online, and have it shipped to you in a hazmat package. Unless for some reason that wouldn't be accepted in your country?
Puan 1
2 Yorum:
Shipping to Belgium is not possible.
tarafından
You can try crc or deoxit. Those sound like American products, and may have a problem getting those shipped there as well. Radio a friend in a neighbor country? Get bransonic shipped there? Then smuggle back into Belgium?
tarafından
Yorum Ekle
Yanıtını ekle
Mattis sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 25
Her zaman: 5,160
