Ana içeriğe geç
A1706 / EMC 3071—Released in November 2016, this 13" Macbook Pro introduces the OLED Touch Bar. Features a dual-core "Skylake" Intel Core i5 CPU and four Thunderbolt 3 ports.
224 Soru Tümünü görüntüle
How to Repair the black strip that says MacBook Pro
Hi I noticed something got stuck in the crack where the screen folds down. Now I have a pressure crack/ hole. can that plastic strip be replaced instead of replacing the whole screen etc..
Thanks
Julie
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 3
3 Comments
Have you repaired it? I have the same problem, happened today
tarafından
It can be replaced. I have seen these parts available.
tarafından
Where can you buy the parts? I have the same issue with my 13" Macbook Air too
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Yes the chin plate can be replaced! Here’s the part: Chin Plate and here’s a guide that can help you see what’s behind it MacBook Pro 15" Touch Bar 2017 Replace LOGO Baffle on the screen,替换屏幕底部LOGO挡板 Replacement
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yes, it is possible to replace the black strip at the bottom! I’ve actually done it a few days ago and it’s fairly simple. First you need to have a source of heat and heat the bottom strip as it has adhesive on it to keep it stuck down. Once you’ve heated it a bit you need to find something to pry the strip up. You can use anything that’s thin enough to fit into the side of the strip to pull it up. I suggest starting from the corner as under the strip are a few ribbon cables for the display so be very careful! Once you’ve got one corner up just make sure to heat it up as you go along to make it a lot easier. Once you’ve got it completely off make sure you take out any remaining pieces or shards from the old strip. Then you’ll be good to place down your replacement! I hope these instructions were descriptive enough to guide you through the process :)!
Puan 0
1 Yorum:
Oh man is this an old post. I just checked the date of when it was posted.
tarafından
Yorum Ekle
Yanıtını ekle
swimmer35 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 13
Son 30 gün: 56
Her zaman: 2,323
