Ana içeriğe geç
Repair information and guides for the iPhone 6S Plus that was released on September 25, 2015. Model A1687, A1634
Right side of backlight dim
Just replaced my screen with the screen from here and it worked perfectly until I put my phone in my case and then removed it again. As soon as I put bending pressure on the top right to pull it out of the case, the right side of the screen loses backlight. I open the phone again and it works again until I slightly bend the top right corner like I'm removing it from a case. I can tap & bang all areas of the phone and its perfect. So long as I don't take it out of the case, its fine. I redid the install to make sure all plugs are in perfectly and they are. Checked cables for rips and ensured I didn't open the screen more than 90 degrees. What could it be? I'm about to trade the phone in so it's not a show stopper... Just curious.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
It's possible that the replacement screen is defective. I would try to re-install the original, cracked screen to see if that exhibits the same symptoms. That will help you understand if the problem is with the screen or on the logic board. If it is the screen, contact iFixit support.
Did you disconnect the battery before removing and installing the replacement screen? The iPhone 6S seems particularly sensitive to backlight failures when the battery is left connected. If this is the case (and the original screen confirms a logic board issue), then the only solution is to have it repaired by a micro-solderer.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Christopher Phipps sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 8
Her zaman: 416
