Laptop makes all HDD runs at 100%
All hard drives running at 100% usage for any program (mostly "system") on new laptop. Hard drives continue to run slowly after being put back in working laptop. Unless it's because of the bios it is a hardware problem not a software one.
Larger images from HDD killing laptop and slightly smaller images from Good laptop that has never harmed a HDD
Edit
The drive went back to normal after playing some games. Work fine on both laptops too.
Edit
The problem is back.
Bu iyi bir soru mu?
1 Yorum
So the problem still persist . I thought it was fine after the game test but days later the drive is running at 100% usage, in task manager for simple programs. Unless it has something to do with the bois of the laptop, it is a hardware problem not a software problem. I'm positive that my test have shown that. I've ordered new SATA connectors because the old one broke off. I've also read that a bad battery could be the problem. I'll be getting a new one and some cheap hard drives for testing, might even have to purchase a working laptop of the same version as a control study (or what ever the proper term is). If any one could save me the trouble of having to buy another laptop by telling me which pins and connectors to measure and what the readings should be, that would be greatly appreciated. It will be a long time until I get the other things. Please let me know something before a spend an unnecessary amount.
Marcus Sleeman tarafından
