Ana içeriğe geç
Sit-on-top lawn mower. Zero-turn radius mower, 50" mower deck, hydro transmission.
Battery has power but no electrical components respond
Battery has power but no electrical comps responsive. Has new ignition switch and battery. Engine turns over when I jump across solenoid with wrench.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
If you have to bypass the solenoid then odds are you need a new solenoid . If the electrical components are wired through the solenoid then nothing will work if the solenoid is fried . Replace the solenoid . Hope this helps
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
My hour meter won't even come on. Battery is good but no electricity going to anything
tarafından
Mine is doing the same thing. What did you find?
tarafından
Yorum Ekle
@kerrycollins check your seat switch (11)for continuity when pressure is applied. Check your circuit breaker (24) to make sure it is engaged.
Puan 0
Yorum Ekle
There is a 20amp fuse across from the battery check that I’ve had the same symptoms turns out that’s what it was.
Puan 0
Yorum Ekle
Yanıtını ekle
Kerry collins sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 29
Her zaman: 2,426
