Ana içeriğe geç
Toshiba Satellite C75D Dizüstü Bilgisayar. 2013 yılında piyasaya sürülen, Toshiba'nın "bütçe dostu" C serisi dizüstü bilgisayarlarından biridir.
How do I replace the LCD Cable
How can I replace the LCD Cable on the Toshiba C75D. I don't know how to disengage it from the motherboard. I don't know if it is soldered or not.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
It looks like it's a cable as in Step 10 here: IBM ThinkPad X41 LCD ekran değişimi
or in Step 12 here: ASUS K75VM bozuk LCD kablosu değişimi
This one's actually a Toshiba, if it makes you feel better. Step 7, middle picture: Toshiba Satellite A215 Teardown
Basically, it's likely not soldered down but do be careful when unplugging it. The pictures above should give some idea of how to do it, but I'd also say to throw in some patience.
You got this!
Toshiba Satellite A215 Görseli
Kılavuz
Zorluk:
Orta
IBM ThinkPad X41 LCD ekran Görseli
Kılavuz
Zorluk:
Orta
30 minutes - 1 hour
Asus K75VM bozuk LCD kablosu değişimi Görseli
Kılavuz
Zorluk:
Orta
25 minutes - 1 hour
Bu yanıt yardımcı oldu mu?
Puan 2
2 Yorum:
Thank you so much for your answer. I can't see how to unplug it....whether it is pulled straight up....slid to the side, etc. Is there a video somewhere that actually shows how to remove it?
tarafından
@marie540 Here's a video of someone removing an LCD cable from a Dell laptop (skips to the important part): https://www.youtube.com/watch?v=1_99jpJe....
And here's a video of someone replacing an LCD cable in a Toshiba (skips a fair bit, but it's a long and slow-paced video): https://www.youtube.com/watch?v=FzB4S6hq...
At about 15:32, he says that the cable eventually failed, and opens it up, if you're interested in that. You can see that the wires are frayed and broken, and he recommends opening and closing the laptop as little as possible to reduce the strain on the wires in the hinge.
Hope this helps!
tarafından
Yorum Ekle
Yanıtını ekle
Marie OKeefe sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 13
Her zaman: 1,970
