Ana içeriğe geç
The Nintendo Switch is a handheld game console that can be played on the TV via a docking station, or on the go. Released March 3rd, 2017.
707 Soru Tümünü görüntüle
What Are The Replacement Screws For The Switch Backplate?
Where On Earth Is This Part?
(Screws For Console Backplate, NOT JOYCONS)
So my Switch is missing 2 screws, one on the top section of the device (the screw hole near the Switch's fan hole) while one screw is missing near the bottom near the charging port. Strangely enough I do not know how these screws went missing, but I will indeed try and purchase a repalcement back for my unit, however I can never find what screws are used at all anywhere on Google, even most Ebay and Amazon serches return with suggestions of Joy-Con replacement screws,which is soemthing I do not need, I need the screws primarily for the back plate of the device. Does anyone know where to get these screws and what screws are used in the back housing of the switch? (and yes the top and bottom more specifically )
Bu iyi bir soru mu?
Puan 2
7 Yorum
@Shane Pe helped me solve this by linking the screws that fit my switch perfectly! His advice can be found in a comment reply bellow! Thank you so much!
Assembly screws for switch on Ebay!
https://www.ebay.com/itm/For-Nintendo-Sw...
tarafından
Thanks. But upon closer inspection it seems that there aren’t any Y000 screws. Those are the ones at the back of the switch.
tarafından
Your suggested link or Shane Pe's? because his are the full assembly screws, every screw for the main console.
tarafından
Shane Pe’s are only joy cons replacment screws. I am looking for some for the back of the switch. At the back without the joy cons there are 4 screws at the corners of the switch. I need those ones. The ones that require a Y000 screwdriver to take out.
tarafından
Its not the Y000 but a set of screws that fit that back area. I read the description and found a picture clearly separating a set of console screws from joycon screws, please take a look at the listing again.
tarafından
2 tane daha yorum göster
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
i believe its M1.4x2mm flathead black screw.
Bu yanıt yardımcı oldu mu?
Puan 2
7 Yorum:
any link or image of this?
tarafından
oh ok so this will work on the top and bottom on the back plate? I went ahead and accepted your answer but get back to me about that
tarafından
I use my caliper to measure the screw and bought for myself. i will deliver results of fit when they arrive
tarafından
Did the screws arive yet?
tarafından
Yorum Ekle
(The description from the seller even shows console+joycon screw separation)
Assembly screws for switch body on Ebay!
Puan 1
1 Yorum:
any comment on that shipper? did it arrive quick. also how many screws did you get, i cant tell if its just the joy con screws or the whole console
tarafından
Yorum Ekle
Yanıtını ekle
natclay96 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 35
Her zaman: 14,014
