Ana içeriğe geç
Lenovo IdeaPad 300-17ISK, Ekim 2016'da piyasaya sürülen 17 inçlik bir dizüstü bilgisayardır. Model numarası 80QH008MUS'tur.
Fan Replacement without heatsink
Hi There, I was wondering if there will be any issues replacing the fan with one of same size but no (what I believe to be) heat sink? Whatever the Copper attachment is. The fan bearing went bad so now it shakes and makes a lot of noise when I use my laptop which is quite annoying, I deal with it by using headphones but can't really take it out because of how loud it is. If I can't replace the fan with aftermarket fans that don't have the copper attachment is there anywhere I can purchase the same fan used for this laptop?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi,
Here is a link to the service manual for your IdeaPad.
Scroll to p.55 to view the necessary pre-requisite steps and then the procedure to remove the fan/heatsink assembly.
Scroll to p.87 to view the parts numbers (#12&13) for the fan and heat sink. Search online using the appropriate part number only to find suppliers of the part that suit you.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
this is what you need. https://www.ebay.co.uk/i/192312127707?ch...
Puan 1
Yorum Ekle
Yanıtını ekle
Kevin Nguyen sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 8
Her zaman: 760
