Ana içeriğe geç
4-inch iPhone released in March 2016 with similar hardware specifications to the 6S. Available in Silver, Space Grey, Gold, or Rose Gold with 16/32/64/128 GB storage options. Model: A1662 and A1723
1049 Soru Tümünü görüntüle
I dropped my phone off to get looked at and it isn't working now.
I dropped my phone off at an apple store to get it looked at to make sure nothing was wrong with it and I just got it back and it isn't turning on so I obviously I thought it was dead so I plugged it in and it still won't turn on. (Yes I know I need a new phone if it is having this many problems.)
Bu iyi bir soru mu?
Puan 0
8 Yorum
what was wrong with it that you needed to take it to the apple store
tarafından
I dropped it in water 2 months ago and it is starting to overheat, battery expanding, turns itself off, and dying even when charging.
tarafından
did the apple store say they repaired it
tarafından
They told me all was good and I payed and left. They didn't give me my phone till after I paid and now I know why.
tarafından
apple store doesnt fix water damaged phones so obviously they didnt do anything. better sending it to ipad rehab or sts telecom. im sure jessa or jason could sort it out
tarafından
3 tane daha yorum göster
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
@cullin Apple will not repair your phone since it was water damaged. You can try and have an independent repairer like @refectio take a look at it. You need to let us know what Apple charged you for. Was it for a repair (doubtful) or an evaluation? I doubt you'll get a refund but you can always try.
This "I dropped it in water 2 months ago and it is starting to overheat, battery expanding, turns itself off, and dying even when charging." is a good sign of what is really going on with your phone. Most likely your battery has finally failed. You did not tell us if you ever took care of the water damage or if you left it untreated. If untreated then this would be about the time I'd expect corrosion to set in and your battery to fail. As much as I despise Apple and other companies that treat consumers like they do, this may actually not be their issue. Open it up, clean it, replace the battery and then re-evaluate.
Bu yanıt yardımcı oldu mu?
Puan 4
6 Yorum:
Yeah, I took it to an independent repair store and they said there is a short circuit and corrosion, but will the phone completely die if the corrosion isn't fixed?
tarafından
@cullin yes it will and may already have done so.
tarafından
How long does it take to completely die from corrosion?
tarafından
Days, weeks, month it all dpends. If may be corrosion it may be solides left by the liquid. There is no exact timeline as for when it shortens out component or corrodes pathways and solder pads. Hence the importance of cleaning asap instead of waiting.
tarafından
Do you know how much it usually costs to clean it?
tarafından
1 tane daha yorum göster
Yorum Ekle
Take it back to the Apple store, you paid them to repair it and it got worse. They likely shouldn't charge you again.
Worst case scenario get a refund.
Puan 3
2 Yorum:
Is there a certain amount of days I have to go back and get my refund? Like some sort of warranty or something?
tarafından
@kcrney. Apple will not repair this since it is water damaged. You will always pay for having them look at it and we do not know what the charge was for or high the charge was.
tarafından
Yorum Ekle
Yanıtını ekle
Cullin Roberts sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 142
