Ana içeriğe geç
Bu bilgisayar, AMD işlemcili ve dokunmatik olmayan ekranlı bir Dell Inspiron 3000 Serisi dizüstü bilgisayardır. Model numarası 3541'dir.
Laptop keeps losing internet connection
I purchased a new laptop at the start of September. It's been working great, except in the last two weeks I keep losing my internet connection.
Within just the last two weeks, I've had some other family members come to live with me. They're able to access the internet with their devices, no problem. But my computer keeps losing its connection.
Even during the times I can't access the internet, my computer shows that it's connected to the network. The built-in network troubleshooter can't find anything wrong. If I restart the router, sometimes it helps. Sometimes it doesn't. Even if it helps, it's only a temporary fix.
I've tried using different browsers, disabling firewalls, restarting the computer, updating OS software, scanning for malware, etc. I'm at my wit's end.
Any ideas?
Bu iyi bir soru mu?
Puan 7
18 Yorum
Hi @caitlin ,
How are you connected to the router, ethernet cable or WiFi?
If WiFi try connecting by ethernet to see if it works OK this way and proving whether it is a WiFi problem or something else (or vise versa if you are connected the other way) ;-)
tarafından
I'm usually trying to connect via WiFi. I tried connecting via ethernet cable when my WiFi dropped again this morning, and I was able to connect. I can't understand why the WiFi isn't working, though.
tarafından
Have you tried updating the WLAN drivers from the Dell support webpage? http://www.dell.com/support/home/us/en/0...
Just type in the Service Tag written on the label on the back of your laptop, choose drivers from the menu, then find it myself and download and install everything under Wireless.
tarafından
hai
I am also facing that wifi connection problem with my laptop.
tarafından
Hi @pravin007 ,
Did you read my answer directly below and try to implement any of the recommendations?
What is your laptop make and model number if it is not a Dell inspiron 3541?
tarafından
13 tane daha yorum göster
Yorum Ekle
13 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi @caitlin
In Device Manager expand the Network Adapters entry and then look for any entry with Dell Wireless in its title.
Right click on the entry and select Properties then select Driver. Check to see if the driver is Version: 7.35.333.0 ,A04.
If it is you have the latest driver already installed.
If it is a lower version number, here is a link to the latest Win10 Wifi drivers for your laptop. Ensure that the OS category on the page specifies Win 10-64bit then scroll down to find Dell Wireless 1704/1708 WiFi driver Download and install the driver and see if it makes a difference.
If you still experience problems even with the latest driver installed then perhaps you could try downloading and installing a free WiFi scanner program.
It will give information regarding your WiFi network. By looking at the results in the program you can identify your network, check the WiFi signal strength being received by your laptop, you may have a loose WiFi aerial connection in the laptop for example (remember the dBm values shown by the program are -ve values, so the higher the number the lower the strength of the signal), how many other nearby WiFi networks are sharing the same channel etc,
If there are more networks sharing the same WiFi channel, switch the channel in your router to a quieter one, i.e. one with no appearances in the scanner program channel list or one with the least.
Let us know how you get on
Bu yanıt yardımcı oldu mu?
Puan 2
3 Yorum:
Hi, @jayeff. I tried your suggestions about checking/updating the drivers and I also downloaded the Intel PROSet/Wireless software tool from the Dell website and ran it to repair the files. That temporarily worked, but this morning I can't connect via WiFi again. Not sure why fixing the files would have fixed the problem for only a few days!
I will try the WiFi scanner today. Thanks for you help, and please let me know if you have other suggestions.
tarafından
Hi @caitlin ,
Have you tried "uninstalling" the WiFi adapter in Device manager then restarting the laptop and let Windows "find" it again and see if that works?
Other things to try:
1. suggest that you try an "sfc" command just to verify that your Win 10 system files are all OK.
2. Check if there was a Win 10 system update on your laptop since you bought it. If there was did the problem start occurring after that date? Go to Start > Settings > Update and Security > Windows Update > View your update history. You mentioned below that the problems started on 10/2/17 so perhaps the update your looking for might be around this date. You may have got the Window 10 creators update 1703 at about the same time How to check Win 10 version number
3. Have you installed any new programs about the time that the problem started happening? Right click on Taskbar and select Task Manager > StartUp and see what programs are loaded at startup. Are there any programs that are unfamiliar to you? Be aware that there may be some that are necessary etc so if you don't recognize them "Google" the name to find out about it.
tarafından
How can you download a driver if you can't get on the internet? I've had the same problem, first with my WiFi connection...I figured my wifi card went bad, so I hooked up with an ethernet cable, that worked for a couple weeks, now the same problem with the ethernet connection. It sees that there's a strong internet there but will not connect to it, no way, no how. All other devices in the house can connect just fine.
Is this common in Dell Inspiron computers...?
tarafından
Yorum Ekle
En Yararlı Yanıt
I had the same issue (loss of WiFi connection without any indicator that there has been a disconnect, happens regularly, but with no pattern and the final straw, loss of Bluetooth connection). As this was a new purchase I called Dell and was given the instructions to uninstall Smartbyte. Bluetooth back and no dropout for the last six hours (yes that is a record). PC = Dell Inspiron 15 5570.
I hope this helps someone out there in Dell land.
Puan 5
1 Yorum:
Was the Smartbyte uninstall a permanent fix?
tarafından
Yorum Ekle
smartbyte was the culprit ... i send a complaint to rivet software ... because dell never listen people ...
Puan 2
2 Yorum:
Was this a permanent fix?
tarafından
I made an account just to up vote your comment. It helped out
tarafından
Yorum Ekle
If you have SmartByte installed from the Microsoft store. try turning it off.
Puan 1
4 Yorum:
I had the same issue and contacted Dell Support. The person helping us said to uninstall the Smartbyte drivers and it worked.
I tried all the other suggestions around drivers, resetting windows and power settings to no avail.
tarafından
Samrtbyte was the issue for me. gone, now Wifi is great
tarafından
Any subsequent issues since uninstalling Smartbyte?
tarafından
No issues since uninstalling for me.
tarafından
Yorum Ekle
It maybe because your modem is not functioning correctly maybe need to get a new one.
Puan 0
Yorum Ekle
Change your wifi settings from whatever you ssid channel is to 11. It s in the router set up. In you browser go to 192.168.0.1 the password is normally :admin and pasword should be an alpga numeric code printed on the router/modem you recived from your ISP.
Puan 0
2 Yorum:
admin- is the usual username
tarafından
It seems that my WiFi is already set to that channel!
tarafından
Yorum Ekle
Assuming that it is running on Windows 10 (recent purchase), make sure you are connected with Ethernet and that you can connect to the internet. Go to Control Panel- Device Manager and look for the wireless device. If it has a yellow triangle on it then it means that there is a problem with the driver or the hardware. Right click on the wireless device and select Uninstall and if it asks click the box to delete the driver. At the top of Device Manager is a tab called Actions, click on it and select Scan for Hardware Changes. This should force the OS to download the driver and install it. If this is not running on Windows 10 then this may not apply.
Puan 0
4 Yorum:
I'm sorry if this is a stupid question, but how do I know what the "wireless device" is? I don't see any yellow triangle and I don't want to uninstall the wrong thing.
Thanks!
tarafından
Look under networking devices
tarafından
Hi, @lightnwire. I tried this but unfortunately it didn't help...there was no yellow triangle, but I did as you suggested anyway. When I right-clicked on the wireless device, hit Properties, and hit Driver, I noticed that the driver date is 10/2/17, which is the day these problems started for me.
Do you have any other suggestions?
tarafından
As Jayeff mentioned, it could be a hardware problem. If you can remove the bottom case then you can try reseating the wifi adapter. It is a small card about the size of an airmail stamp and should have at least 2 antenna wires connecting to the card. Try reseating the card without removing the antenna wires, the little connectors are tricky to connect back on the card. You can rotate the antenna wires about 15 degrees and that should be enough to clean the contacts. The contacts are micro coax connectors, if one is not connected then try to line it up and wiggle it as you push it down. Make sure that the color wire matches the correct connector, there is usually a white, black and blue dot by the connecters.
tarafından
Yorum Ekle
I never saw where the problem was solved...I have been experiencing the same problem since purchasing my Dell laptop in Aug. After countless hr with remote support, two in home tech, and one replacement laptop. One hr with wireless service tech, updated routers, the problem still exists....I am using my tablet, of which I have no problems. I am at my wits end.
Puan 0
2 Yorum:
Hi Linda. Yeah, unfortunately I am still having this issue after exhausting basically all options (and all recommendations offered by the above posters).
I, too, have tried EVERYTHING...all kinds of tech fixes and troubleshooting, updated routers, went through Dell tech support, etc. No luck fixing the problem! Wish I had some solution to share, but I don't. :(
Sometimes my wifi on my laptop works and sometimes it doesn't. I usually have 1-2 outages each day. Sometimes they last less than an hour and sometimes they last many hours. Really wish I could figure this out!
tarafından
Me too :( %#*@ dell laptops.
tarafından
Yorum Ekle
Wireless somehow works after turning the Firewall off. Not sure if this is a permanent fix or not.
Puan 0
Yorum Ekle
Caitlin - Did you try the Smartbyte Drivers as suggested?
My daughter's laptop has been having the same issues since purchase and hours of support over the phone with Dell still not resolved.
Was going to try the Smartbyte Driver uninstall, but before I did wanted to know whether this resolved the issues permanently?
Puan 0
Yorum Ekle
For some reason my computer after nearly a year suddenly had "power savings" turned on. I never set it, and it started doing the drop wifi connection after 7 minutes even when plugged in the computer would "shut off" the wifi.
First fix:
Disable it in power management: Slide the mouse down to the bottom-right corner, then once your right-side navigation thing pops up go to the top ‘Search’ (ClassicShell: Press the Windows key In the text box at the bottom) type “Edit power plan” and click the result.
Change advanced settings. Open up the “Wireless Adapter Settings” then “Power Saving Mode” and make sure it doesn’t disconnect your wifi to save power by setting . Switch it up to Maximum Performance which should stop it from disconnecting at random.
This actually worked on my computer for about few days when the wifi would start dropping again even when plugged in. As it turns out I found another step to fix laptop keep disconnecting issue here (the another place to get your issues resolved). I am mentioning the steps below
Second fix:
Go into your network settings. Control panel again.. Mouse to the bottom-right, ‘Search’ again. This time type “Control panel” and click the result. From here we want “Network and Internet” and then “Network and Sharing Center” and from there “Change adapter settings” (It’s on the left hand menu bar)
Right click your wifi adapter -> click Properties -> click Configure -> click Power Management
Uncheck the box “Allow the computer to turn off this device to save power”.
Puan 0
Yorum Ekle
Got the low down on this Dell comm issue.
I got a new mesh wireless network.
That action failed 2 dell laptops from obtaining internet connectivity.
“SECURED, NO INTERNET”.
The answer is to cold start computer while tapping F2 until BIOS screen appears.
Select “Load defaults” and select “BIOS DEFAULT”…..NOT factory default.
Reboot.
Connectivity then restored perfectly.
Puan 0
Yorum Ekle
Hello,
Jason Kate Stone
This is a major issue, Many user reporting this issue . It is a very frustrating issue, you can resolve this easily . Using few method you can try to WiFi connection stable again. You can resolve this by,
  • Change the power management setting.
  • Reset the WiFi configuration setting.
  • Network adapter driver.
But you can resolve your any another method also. But check these method for '''how to connect dell laptop to wifi''' . i hope these method resolve your issue easily.
Puan -1
Yorum Ekle
Yanıtını ekle
Caitlin sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 14
Son 30 gün: 91
Her zaman: 129,192
