Ana içeriğe geç
Stuck in deeper dfu-mode
Hy everyone!
Got an Iphone 6 plus from a friend witch fell down on the floor and broke the screen and battery.
Got me a replacement for the battery and now i am stuck in the dfu-mode.
If i connect the phone to the pc, itunes say's that it found the device and need's to restore it. And then it tell's me that there is no software for this device available.
The update button is greyed out.
Itunes is up to date!
I think it could be a hardware related problem but i don't know where to start.
I could try to heat up some parts of the logicboard.
But what...?
Thanks for any hint!
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
5 Yorum:
download reiboot and see if it will take it out of dfu
tarafından
you could also try 3utools.com, download it, take it out of DFU and try to update it there. What is the current IOS on it? Are you using Vista or windows 7 or 10?
tarafından
Allready tried Reiboot, it doesn't recognise the phone as connected...
Thanks
tarafından
I am using win 10 64, and i don't know that was on there. My guess is ios9.
The main problem is i can't get out of dfu mode. And i don't see any apple logo because of broken screen. 3utools tells me i have to press that buttons i allready did.
tarafından
if in DFU mode, even having a working screen would not show an apple logo as DFU will not show anything but a black screen. What message is 3Utools giving you exactly?
tarafından
Yorum Ekle
3 Cevap
Filtre ölçütü:
there is nothing i can do... just a hint
Bu yanıt yardımcı oldu mu?
Puan 0
5 Yorum:
First, I would try to reset/flash it and see if successful. It should kick you out of DFU mode during the flash...but either way will need to get a working screen to continue with setup if successful so you can see the progress.
tarafından
waiting for idevice and something like device not supported/ unsuported hardware
tarafından
Hmmm....I have not ran into that before so I guess I hit a roadblock with you, but hopefully someone will pick it up from here that knows what is going on. Just curious, have you disconnected battery, then remove the screen. disconnect back camera too and all flex cables except the charging port. Reconnect battery and then connect back to 3Utools or Itunes and try from there?
tarafından
yes, i tried. Thanks for now!
tarafından
Let me know what you find...I am curious to know...Best of luck!
tarafından
Yorum Ekle
i don't get it!
Puan 0
7 Yorum:
I honestly don't know either...unless you have a corrupted NAND and it needs reprogrammed with Naviplus. I will wait to see what others think as I have not experienced this before and don't want to misguide you
tarafından
Thanks for no anyway, I'll let you know if i find anything in this case"
tarafından
have you turned off find my phone in icloud
tarafından
The phone is definitely not in condition to communicate with any server..
at least that one thing i know
tarafından
You can still log into icloud.com from computer and delete the device from your device list to turn off find my iphone. Im not sure if it will make a difference or is somehow stopping you from restoring due to the security, but worth a shot
tarafından
2 tane daha yorum göster
Yorum Ekle
u can change q1403
thank me later
Puan 0
1 Yorum:
This question was 3 years ago.
tarafından
Yorum Ekle
Yanıtını ekle
mischakuh sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 20
Her zaman: 2,331
