Ana içeriğe geç
Repair guides and support for LED, LCD, HD and other Vizio TVs.
How to fix double image
How to fix double image on my vizio smart led tv?
Bu iyi bir soru mu?
Puan 4
8 Yorum
Oldturkey I already edited my post by putting the video, Another description on my problem is when I let my vizio led tv turn on for 5 minutes the double image problem will gone or it became normal
tarafından
It looks like it is in a some sort of a rhythm. Let's take a look at some of your boards.
tarafından
I posted the picture
tarafından
I gently applied pressure but nothing happens on the image
tarafından
I gently applied pressure on the orange thin ribbon inserted in the panel but nothing happens on the image
tarafından
3 tane daha yorum göster
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Redjude Cadornigara most double images are caused by a GATE TAB bond failure. For that, you will have to check the thin orange flat ribbon cables that enter your LCD panel. Now this is the part where we have to see what you see in order to try and help you. Post some images of what your screen shows with your question. That will allow us to see what you see. Use this guide Adding images to an existing question for that. Remove the back of your TV and post some really good pictures of all of your boards and see if you can reach the orange ribbon cables. Apply some gentle pressure on those and see if the image changes.
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
The new TV now a days have life span bet 3-5 years. depending how often you are watching or using the TV. If the life is more than 5 years, good for you. TV Panel as well as electronics boards were not designed to work in a longer years. For any problem in Smart LCD/LED TV like no picture but with sound, solarize picture, no power at all, the stanby lit but not turning on, try to visit my youtube channel DASOL PAN and locate my Playlist How to fix TV. I have some english youtube blogger there that I subscribed. Otherwise try to seacrh on Youtube the problem you have. You can try this one if the video still available:
https://www.youtube.com/watch?v=ejaRVrnD...
If you can understand Tagalog Language, try to watch my Youtube Playlist (How to fix TV?)
https://www.youtube.com/playlist?list=PL...
Puan 0
Yorum Ekle
Yanıtını ekle
Redjude Cadornigara sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 20
Son 30 gün: 74
Her zaman: 19,421
