Ana içeriğe geç
30 amp fusible link blown
The fuse box under the hood has a 30 amp fusible link that is blown. I replaced it and blew again, and was told by friend to replace the fuel pump. Engine turned and problem seemed to be solved but happened again when I closed the hood. Found the right turn signal had a blown wire just behind the light. Since the fuse has not blown but I am waiting for it to happen again.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
@estgarcia85 since it is working for now you may just have resolved that issue. If it happens again, you'll have to check again. Problems like this are really hard to resolve since there is always more than one possibility. Post a picture of this "fuse box under the hood has a 30 amp fusible link" with your question so that we can check the wiring diagram. Use this guide to post images with your question Adding images to an existing question
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Esteban Garcia sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 13
Her zaman: 855
