Ana içeriğe geç
7.9 inch display / Model A1432 / Available in black or white / Announced October 23rd, 2012 / 16, 32, or 64 GB capacity
220 Soru Tümünü görüntüle
blacklight,flickering on iPad mini
Hi i have an iPad mini and i was trying to fix the backlight issue . (I open the screen and i send light to it to see whats going on) . Firstly without make anything the only problem was the blacklight i mean that if you send light to screen with a flashlight you could make anything you want in your device .But now when the apple logo appear make something like flickering (it appear-disappear).and the problem with the blacklight is the same
Update (10/30/2017)
the "flickering"problem appear when i change this component
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Is this a picture of your device or just a picture you found on the web? Have you tested the individual components in the backlight circuit?
I would start by validating that L2200 is in good condition. Then check the diode to insure it is working properly, even if you replaced it. You may have damaged it with too much heat while soldering it. I wold also check the coil. If needed, you may need to replace all of those components plus the driver IC.
Bu yanıt yardımcı oldu mu?
Puan 2
2 Yorum:
i test all the components and they have a good value i think .so i have to replace the ic? (the picture is from internet)
tarafından
If you're confident that the other components are fine, then you can consider replacing the PMIC (U8100). However, that's not an easy IC to replace unless you have some experience so I would exhaust other avenues first.
tarafından
Yorum Ekle
Yanıtını ekle
Κωστας Λαζαριδης sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 7
Her zaman: 1,192
