I need to replace the screen. Can you make a tutorial?
theres a black line down the left side of the screen and I need to replace it.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
It's under warranty. Take it to Apple!
Bu yanıt yardımcı oldu mu?
I fear he banged his system so there is a visible dent on the lid which would void the standard AppleCare warranty coverage but with AppleCare + they will give him a break. AppleCare protection plan
@danj I did not read into the question anything about a dent.
@mayer - I didn't either, its just conjecture given the issue of a black line.
Ouch! Sorry you got a bad display ;-{
Have you tried locating the needed part yet? So far whats available is quite expensive! Retina MacBook Pro 15" Complete Display - Silver $1,232.60 US.
I would recommend you see what Apple charges for a replacement. If you have Applecare + before you go in it will be cheaper <hint!>
"Coverage for up to two incidents of accidental damage, each subject to a service fee of $99 for screen damage or external enclosure damage, or $299 for other damage, plus applicable tax"
For reference review the steps in replacing the older system: MacBook Pro 15" Retina Display Mid 2015 Display Assembly Replacement. Unlike the older models which used a hollow hing to pass the lines from the display this series uses the middle clutch cover at the entry point. There are two compression connectors that break the ribbon connections.
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 140
