Ana içeriğe geç
The HP Pavilion g6-1b79dx is a 15.6” laptop with a pewter finish made in 2011. It has an integrated webcam and an Intel Core i3 processor.
Unable to delete 0 byte file.
I was playing with batch files and accidentaly created a 0 byte, no extention file.
I googled the problem and I found out that closing explorer.exe and deleting the file via command would help. Tried that. It didn't help. Any software that could do it? Any other suggestions?
Thanks for your help in advance :)
Bu iyi bir soru mu?
Puan 0
7 Yorum
Honestly, if its doing no harm to the laptop, you should probably just leave it.
tarafından
It's taking up space on my desktop. I need that space :(
tarafından
I would suggest using an administrative login to examine the file permissions. You need to open up the permissions and try the delete again afterwards. Windows file system permissions can make you want to resort to violence at times. Use of cygwin can help sometimes when all else fails.
tarafından
If its just taking up space on the desktop, you can set the file to be hidden so you cannot see it unless you have view hidden files enabled. also what is this File Unlocker thing mentioned in the file description?
tarafından
@professorc I doubt changing the permissions would do anything. Cygwin on the other hand might. I'll try that. Thanx for your help.
tarafından
2 tane daha yorum göster
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
As I stated earlier.... Windows file system permissions can make you want to resort to violence at times. Use of cygwin can help sometimes when all else fails.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
En Yararlı Yanıt
Create a new profile in Windows with admin privileges.
Log out of the current profile.
Log into the new one.
Use explorer to go to your other profiles desktop location.
Manually delete that file.
Puan 1
2 Yorum:
Thanks for your answer but explorer.exe simply does not see the file as... a file. Creating a new account would probably do thesame as killing explorer.exe and deleting the file via cmd which did not help as I said in the question. Thanks anyway.
tarafından
From the new profile open a new profile, open a command prompt with administrator privileages, and then use command prompt to navigate to where the 9 file is. Then "rmdir /s <file name> or del <file name>.
tarafından
Yorum Ekle
Yanıtını ekle
SLimy sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 6
Her zaman: 678
