Ana içeriğe geç
Birinci nesil Mazda MX-5 veya Miata.
Timing belt broke while driving
I have a 1997 Mazda Miata. The timing belt broke and I want to know if there could be any other extensive damage to the engine before I have it repaired. Is there any way of determining other damage?
Thanks;
Pete
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
From what I've been able to see on line in miata forums these older miatas are non interference designs that won't eat the valves when the belt turns loose. Removing the valve cover and manually turning the cams can confirm this... If any valves show massive clearances at any point of rotation it is of course indicative of bent valve stems. Naturally if you encounter serious resistance trying to turn a cam you should refrain from forcing it.
Bu yanıt yardımcı oldu mu?
Puan 4
Yorum Ekle
@fullcircle15 the Miata engines are non-interference engines. You should not have any piston/valve damage.
Puan 4
Yorum Ekle
Yanıtını ekle
peter shea sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 34
Her zaman: 3,768
