Will not power up. Does not show up when plugged into computer
Will not power up. Does not show up when plugged into computer. tried new batteries and taking them in and out a bunch of times to try and reset. no lights at all
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Ephiram Bosse time to take a closer look at it. you do want to check the battery connections to make sure that the battery provides power on the connector. After that you want to check the micro USB connectors on the motherboard to make assure all of that is connected/soldered. Post some pictures of your boards so we can see what you see. Use this guide Adding images to an existing question for that and use this guide GoPro Hero3+ Black Edition Motherboard Replacement to work on your GoPro
Kılavuz
Zorluk:
Çok kolay
2 - 5 minutes
Kılavuz
Zorluk:
Orta
10 - 15 minutes
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 45
