Ana içeriğe geç
The Kenmore Direct Drive is a washing machine by Kenmore.
Washer Leaks Only During Agitation Cycle
Have noticed my "Whirlpool" direct drive top loading washer leaks only during agitation, to include washing and rinsing cycle. It's a pretty intense leak as well, to the point where I can watch the soap bubbles run across the floor to the lowest spot. I'm pretty sure I can just replace the gasket/seal on the bottom of the agitator, but I wanted to get someone else's opinion before I pull my washer apart. After perusing many websites and much googling, I have yet to find a decent guess.
Bu iyi bir soru mu?
Puan 0
1 Yorum
After roommate reported that it only leaked during SuperCapacity Wash Cycle, I tested it again. Washer only leaked during beginning and end of agitation cycle with an extremely light load. Also a little more during rinse cycle, but nothing serious.
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Cause 1
Tub Seal and Bearing Kit
The tub seal might be torn, causing water to leak from the seal. If the tub seal is leaking water, water may leak through the tub seal and into the tub bearings. This can cause the bearings to fail. For this reason, if the tub seal is leaking water, replace both the tub seal and the tub bearings. Be aware that this is a complicated repair and will require disassembling most of the washer.
Cause 2
Tub Seal
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
This sounds exactly what my washer is doing so I'll try it
tarafından
Yorum Ekle
It is possible that if the water level is set to extra large load OR the water level sensor is malfunctioning and putting too much water in the tub, and the load is actually small, the agitation might throw water over the top of the outer tub.
Otherwise, why would it only leak during agitation. I would think if there is a bad seal, it will leak any time there is enough water in the tub to over pressure the seals.
Puan 0
3 Yorum:
I put cardboard down in front of the washer at the bottom while it's agitating and I can see that it's slinging water onto the cardboard so I know it's leaking somewhere just don't know where I'm thinking it's the bottom of the tub I don't know let me know what you think
tarafından
I’m having the exact problem now. What was your fix?
tarafından
@killingsworth29
I’m having the same problem now. What was your fix?
tarafından
Yorum Ekle
Yanıtını ekle
Brian Graves sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 43
Her zaman: 7,991
