Ana içeriğe geç
22 Eylül 2017'de satışa sunuldu. Model A1863, A1905 olarak tanımlanıyor. GSM ya da CDMA olarak 64 ya da 256 GB kapasitelerinde, Altın, Gümüş, ve Uzay Grisi renklerinde satılır.
Backside Metal or Plastic?
Is the iPhone 8's backside under the glass of metal or plastic?
Thank you.
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
5 Cevap
Filtre ölçütü:
Seçilen Çözüm
The outer housing (perimeter) is aluminum while the inner back plate is stainless steel. Check out this teardown guide.
Bu yanıt yardımcı oldu mu?
Puan 3
1 Yorum:
@danj is correct, I have amended my answer...
tarafından
Yorum Ekle
It looks like steel to me.
The spot welds along the edge of the studs are bluish which is what steel would look like. In addition the thinness of the metal given the needed strength would imply steel as well. True the outer side edge is anodized aluminum!
Puan 2
Yorum Ekle
It is metal. See this phone
Puan 1
1 Yorum:
Mandy you are correct. It is made from stainless steel.
tarafından
Yorum Ekle
Hi, the back is metal with a frame (Al) and covered with Glass.
Puan 0
Yorum Ekle
It is metal covered with glass, however i don,t recommend this phone if you want a strong one a video from the channel jerryrigeverything the back glass broke dramatically after only the second from lap fall . If you a good powerful phone i would recommend the xperia xz premium.
Puan -1
Yorum Ekle
Yanıtını ekle
Hans sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 606
