Ana içeriğe geç
Samsung's flagship phone, the Galaxy S8. Released in April 2017.
304 Soru Tümünü görüntüle
How to maintain water proofing?
What adhesive parts are required in order to maintain water proofing on the S8 after a front/rear glass replacement? I notice that often when the rear glass is replaced, many people say that despite putting adhesive, it will no longer be waterproof.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
I believe that it is because it is not done in the same controlled environment as Samsung, and in most cases a far worse adhesive is used. The adhesive might be good enough to keep the back in place, but not tight enough the keep water out.
Even if you could get the same adhesive, you would need a completely dustfree environment, so there are not gaps in the adhesive, and put correct pressure and maybe even heat to stick it on correctly
Bu yanıt yardımcı oldu mu?
Puan 4
Yorum Ekle
I would say get the rear adhesive for the phone put it on the glass, put the glass on the phone press down on all edges, then put heat on the glass and put pressure on it after you have put heat on the glass. It may then be waterproof again .
Puan 0
Yorum Ekle
Yanıtını ekle
Naeem sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 1,017
