Ana içeriğe geç
Dördüncü nesil iPhone. Onarımı oldukça basittir, ancak ön cam ve LCD bir bütün olarak değiştirilmelidir. GSM / 8, 16 veya 32 GB kapasite / Model A1332 / Siyah ve Beyaz. Bu sayfa, kullanıcıların iPhone 4 cihazlarında sorun tespiti yapmalarına, onarım gerçekleştirmelerine ve destek almalarına yardımcı olmayı amaçlar.
Back panel will not slide back on?
I followed the guides within here to take apart my iPhone 4. And made sure to follow and remember every screw I took out, etc. My question is, whenever I go back to slide the back cover back on...it will not fully slide down into position for the two holes to screw it in place...it seems to be "stuck"... any ideas?
Bu iyi bir soru mu?
Puan 3
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
you need to put a little bit of force, and check out the outter frame that it is aligned with the housing as u slide it on. :)
Bu yanıt yardımcı oldu mu?
Puan 5
3 Yorum:
Thankyou! Put a little more force on it, and bingo, "clicked" right into place no problem. Thanks! :)
tarafından
Please "accept" an answer if it solved your problem so that it can be archived for others to learn from. Thanks
tarafından
You guys helped me out too! I thought I was going to have to reassemple everything. Then I was scared to apply more pressure. Thanks Guys! Who needs apple care?! IFIXIT!
tarafından
Yorum Ekle
This has happened to me a lot and i have found that the reason being, for me at least, is that i forget to make sure the 6 side screws (with washers) aren't tighten all the way. After i retighten those it fits like a charm!
Puan 1
Yorum Ekle
I just broke the !@#$ out of hte back of my iphone doing htis
Puan 0
Yorum Ekle
Yanıtını ekle
Ryan sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 26
Her zaman: 9,546
