After cleaning the fan my laptop does not start
Hi, after cleaning the fan of my macbook air late 2010 following the instructions on:
https://www.youtube.com/watch?v=-1r9yl-P...
and
MacBook Air 13" Late 2010 Fan Replacement
my laptop does not start anymore.
After cleaning it the laptop started for a little while but then switched off and does not do anything when the on / off button is pressed.
I tried to search the internet and tried most of what I could find here:
http://www.makeuseof.com/tag/mac-wont-bo...
The only thing that gives some results is:
- Unplug the battery.
- Unplug the MagSafe power cable.
- Hold down the power button for about 10 seconds and continue to do that.
- While still holding the power button down, insert the MagSafe power cable and hold it for another 10 sec.
- Release the power button after those 10 sec and make a “normal” press as if you would normally turn on your computer.
When I do the last step the fan start spinning as fast as it can but nothing else, in order to switch it off I need to press the on/off button for about 10 second.
If I do the same with the battery plugged in nothing happen.
Any help on what I should do to make my Macbook Air working again?
Cheers
Bu iyi bir soru mu?
