How do I connect my device to the internet?
I want to connect to the internet, but I'm not sure how to do so wirelessly.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
You connect your Amazon Echo Dot through the Alexa app! Go to settings, select your device, and select set up wifi! I am attaching a link which will give more help on connecting your device to the web.
Bu yanıt yardımcı oldu mu?
Connect echo dot device to Wi-Fi network:
Go to Settings option from the left navigational panel.
Select your device and after select update Wi-Fi.
Try to press and hold action button when the light ring changes to an orange and select Wi-Fi network, enter the password.
Also, Make sure enter password is right to connect to the network.
If you want to connect echo dot to a Wi-Fi network, follow the instructions in the Alexa app. Most important thing that is echo dot connects to dual-band Wi-Fi (2.4 GHz/ 5 GHz) networks that use the 802.11a / b / g / n standard. Echo Dot does not connect to ad-hoc (or peer-to-peer) networks.
To learn more, go to '''Connect Echo Dot to Wi-Fi'''
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 26
Her zaman: 6,987
1 Yorum
still unable to connect,used alexa app
Frank Retkowski tarafından
