Ana içeriğe geç
Apple iPhone 5s, 10 Eylül 2013 tarihinde duyuruldu. Bu cihazın tamiri, daha önceki modellerinkiyle benzerdir; tornavida ve plastik açma araçları gerekir. GSM ya da CDMA olarak, 16, 32, 64 GB kapasiteli Gümüş, Altın ve Uzay Grisi renklerinde mevcuttur.
3530 Soru Tümünü görüntüle
Connector will not go back on
In disconnecting the digitizer cable connector, in trying to replace the front panel on my iPhone 5s, I accidentally unconnected a small rectangular connector next to the battery (not the LCD or front facing camera, they were already off.) Now it won't go back on, Is there a trick to it?
Bu iyi bir soru mu?
Puan 0
1 Yorum
I took it to my local smartphone/tablet/computer repair. The guy at the front desk got out his splunger and had it back on in about a 30 secs. He did some other stuff for me. No charge! ITech Smartphone Repair in St Augustine, FL. Highly recommended!
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
See the comments. I found a guy who fixed it.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
En Yararlı Yanıt
it looks like its broken and the connector above doesnt seem to be in good condition either
Puan 2
2 Yorum:
is it possible that the connector attached to the board got separated from the board and came up with the connector at the end of the cable?
tarafından
It's all possible. That connector has seen better days. If some of the pins lifted from the logic board, then you won't have a good electrical connection.
Try to inspect it under magnification to see. You might be able to re-shape it (be very gentle). If the connector has physically been damaged or is no longer connected, a micro-solderer can replace the connector.
tarafından
Yorum Ekle
Yanıtını ekle
William Kolb sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 2
Her zaman: 62
