Ana içeriğe geç
iPad Mini 4, 9 Eylül 2015'te duyuruldu ve iPad Air 2'nin gücünü daha küçük bir bünyede barındırıyor.
I pad mini 4 screen replacement
Can I just change my glass screen that is cracked on my I pad mini 4; I have taken it to a shop and have been told I have to buy the full casing because you cant just change the glass screen, someone has offered to change just the glass part for me is this possible ?
Bu iyi bir soru mu?
Puan 4
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Just to elaborate on Daniel's answer...
The iPad mini 4 has a fused display assembly (LCD is glued to the digitizer), similar to those found on the iPhone and Air2/Pro iPad models. Technically speaking, if only the digitizer is damaged, it can be replaced independently but this requires a repair shop that has a full suite of tools for screen refurbishment. It is certainly not a DIY repair and even an experienced tech will not get good results unless they have the proper tools. AFAIK, very few people refurbish iPad screens.
Bu yanıt yardımcı oldu mu?
Puan 3
2 Yorum:
I have no trouble replacing just the digitizer and you dont need a "full suite" of tools. Just a tech that knows what their doing.
tarafından Paylaş
Where i can replace screen
tarafından Paylaş
Yorum Ekle
yes you can replace the digitiser
Puan 1
2 Yorum:
Where can I get a replacement digitizer for the iPad Mini 4, without buying the whole LCD + Digitizer assembly?
tarafından Paylaş
you can find them on ebay. tho as minho says its not an easy repair for someone that hasnt done it before as the lcd and digitiser are glued together
tarafından Paylaş
Yorum Ekle
Yanıtını ekle
Penny Crossland sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 26
Son 30 gün: 47
Her zaman: 6,461
