Why is my sd card not dectable?
I put my sd card in my phone nothing shows up i put it in my computer no files or nothing pops up i also tried putting it with a usb sd card reader and nothing shows up can my card be fixed?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Hi @poncebrianna ,
Try cleaning the gold contacts on the card with either a Q-Tip moistened with IPA (Isopropyl Alcohol) +90% or if you don't have any of that on hand, an ordinary pencil eraser will suffice. Do not rub too hard, just enough to ensure that the contacts are clean and bright.
Check if the card is detected when you insert it into a device. If it is not detected then unfortunately the card is faulty and needs to be replaced.
Bu yanıt yardımcı oldu mu?
I have a Garmin Nuvi 65 GPS that needed an external micro SD card inserted for the upgrade. No matter what micro sd card, 4gb, 8gb, 16gb or 32gb, was inserted, it was not recognized. I saw a You tube video using WD40 to clean an iPhone micro sd slot. in my case it worked! the previously non working 16gb card is now detected! My GSP is now installing the latest North America map now!
@ajmorales You might have dust problems now getting into the GPS system. When you can, buy some electrical contact cleaner and spray your GPS card slot to clean the oil residue left by the WD40.
This has just happened to me. I think the micro SD card has failed. I've tried cleaning it, but I know it was perfectly clean as I hadn't let it touch anything between going from packet to card slot. It worked a while in 2 different devices. It failed while inside the 2nd device (had been working fine, then simply not found and it wasn't physically touched or removed in between). So I know it's a fail. Also checked in the 2nd device and it's unrecognised there.
I'd only taken it out of the package over a week ago. It's a Kingston, and cheap. A sizable number of reviews in Amazon, where I bought it, say the same card sold failed while more say it's good and long lasting. Some manufacturers cards' quality may vary from card to card. On the other hand it could be from a virus through Android web connection.
Change brands or get a device capable of storing greater memory.
Son 24 Saat: 4
Son 7 gün: 23
Son 30 gün: 125
Her zaman: 23,501
4 Yorum
Wen copy alot of data to sd cary it masage the sd need to format again an than format it reped the this progect
sayedrasoulfatehi Fathi tarafından
Poor English
jak_jonsin tarafından
Try formatting it in the device and if that fails try formatting it in your computer. If that fails the card may be irreparably corrupted.
Michael Nordberg tarafından
This happened to my Sandisk Ultra 32GB, I used it in my raspberry pi 4 and when i took it out and put it in a HP envy x360 convertible. PLEASE HELP!!!!!!!!!!!
Landon Trotter tarafından
