My iMac keeps shutting down half way through the apple logo
A few days ago, my iMac was being slow and freezing and the beach ball kept popping up,
So I searched YouTube on how to make it faster and the video said to go into the disk utility folder in applications and click on "verify disk" then "repair disk", But, when i did that, it said that I had to restart the computer and press on "command + R" at the same time which I did.
Then I went back to Disk Utility and clicked on verify disk and repair disk, but it said that the computer could not be repaired and that I should delete everything on it and reinstall OS-X!
So then just restarted the computer so I can use it, but it shut down half way through the loading screen and every time I start it up, it repeatedly shuts down half way through the loading screen.
Is there a fix for this? if so, how?
Bu iyi bir soru mu?
4 Yorum
Can you tell us your exact model. Refer to this listing: All iMac's
Dan tarafından
We need to tell you how to replace the hard drive but that procedure is dependent on your exact model. It's listed on the bottom of your stand.
mayer tarafından
Thank you for telling where to find it. I just updated my post and the model of the computer is now shown.
I BarcelonaFame I tarafından
I have the same issue. I have a retina 5K 27 inch Late 2015, 4 GHz Quad-Core Intel Core i7. The computer spontaneously shuts down while the line below the apple is loading.
Nancy Yachnes tarafından
