Ana içeriğe geç
Repair information and guides for the updated version of the 2015 Retina MacBook that was released in early 2016. Model A1534 / EMC 2991
My screen is with horizontal lines after a physical damage
Hello guys! My problem is this: My macbook has suffered damage in the lower right corner, which resulted in my screen with 3/4 horizontal lines of the LDC, the top part remaining normal.
There was no cracking or anything, I did not take my computer to any assistance yet, but I talked to several on the phone and they all want to change my display, at an absurdly expensive price. Is there another option?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hello Arthur,
Unfortunately the whole LCD assembly needs to be replaced :( This repair is difficult for the average person and even the tech proficient. Once you fix it, I would definitely invest in a sturdy plastic case and a Moshi brand ivisor to protect the front. Sorry for the bad news.
Bu yanıt yardımcı oldu mu?
Puan 1
3 Yorum:
Thank’s bro! No problems, I’m searching to buy a new screen and replace myself, which will be a lot cheaper than Apple authorized services here in Brazil. They
tarafından
Here they charge about $ 850 to do this repair, and I plan to spend about 350 ~ 450 dollars fixing it myself.
tarafından
Hello Arthur,
$850 is steep! I would buy the screen from a reputable seller and follow the guide. The guide for the 2015 is basically the same at the 2016. My advise would be to be very careful with step 13, 16, and 21. For step 16 make sure to peel the adhesive off the metal bracket completely or it will stick to the closing latch. Its also easy to forget about the extra slack on the tiny audio cable on step 21 and close the bottom lid on it. You can also modify a regular pick into battery separator pick if you don't want to order one (but it is really handy).
Retina MacBook 2015 Display Assembly Replacement
Battery Blocker
tarafından
Yorum Ekle
Yanıtını ekle
Arthur Rezende de Faria sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 20
Her zaman: 766
