Ana içeriğe geç
iPhone, iPhone 3G, iPhone 3GS, iPhone 4, iPhone 4s, iPhone 5, iPhone 5c, iPhone 5s, iPhone 6, iPhone 6 Plus, iPhone 6s, iPhone 6s Plus, iPhone 7, iPhone 7 Plus, iPhone 8, iPhone 8 Plus, iPhone X, iPhone XS ve iPhone XS Max orijinal ürünleri için nasıl-yapılır kılavuzları ve parça değişim kılavuzlarının tamamı.
36471 Soru Tümünü görüntüle
What glue do you use for glass only replacement
I've been replacing screens for awhile now and generated a ton of broken screens, I recently started removing the broken glass from the lcds.
Just worndering a few things.
1) What is the best glue to use to glue a glass back onto the LCD.
2) Where do you get said glue for the best price.
3) Where do you get your glass at?
4) Any tips or tricks when glueing the glass only back on the LCD?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
For tips and tricks, you should watch the LCD screen refurbished video on YouTube. For glue and glass, you should ask your phone repair parts vendor, also you can buy them in iFixit. Only replace glass need some equipments like OCA Laminating Machine, Bubble Remove Machine and others.
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
You normally use Loca glue + a UV light to set the glue.
https://www.ebay.com/itm/FLASHLIGHT-UV-L...
See this youtube tutorial.
https://www.youtube.com/watch?v=7hzCCsex...
Puan 1
2 Yorum:
All reputable refurbishers are doing OCA. LOCA is fine for one-offs (although not really cost effective). If the OP wants to do iPhone glass-only repair professionally, as the question suggests, they should invest in the proper tools and consumables, as Mandy recommends.
tarafından
OCA and LOCA are the same glue. "L" simply means its the liquid form. The solid form is expensive due to the equipment as you said for a machine that can remove bubbles vs a simple UV light.
tarafından
Yorum Ekle
Yanıtını ekle
Frost tech repairs sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 6
Her zaman: 4,233
