Power On No display
Its Power on but gives display sometimes and sometimes not give display
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Hi,
Connect an external monitor and check if it shows a display OK.
Also when the laptop screen shows no display, use a torch and shine it at an angle close to the screen and check if you can detect a display at all. It will be very faint so perhaps it will be easier if you try this in a darkened room
Bu yanıt yardımcı oldu mu?
try to open it up and disconnect the screen then clean the screen connectors with alcohol assembleitup and retry
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 11
Her zaman: 698
1 Yorum
maybe a loose cable
daniel tarafından
