Ana içeriğe geç
iPad Mini 4— A1538 modelinin Wi-Fi versiyonu için kılavuzlar. 9 Eylül 2015'te duyurulan iPad Mini 4, iPad Mini 3 modelinin yenisidir.
97 Soru Tümünü görüntüle
Fingerprint function does not work
Dear,
I repaired my ipad mini 4 for the first time,
I have an problem with the fingerprint function.
When i replaced the home button and try to test the screen and the function ,my fingerprint does not respond anymore.
I checked in the touch id options and it is not turned of so i think its not broken, also i can just switch it on and off. When i had this problem with an iphone the ios gave an error that the touch id will not work.
Is there any solution for this or what i might did wrong.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum
Yes, replaced everything original, only the solder part i did not, because i read that the solder thing is for the power button sleep mode
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
did you use the original home button, as other home buttons wont let you use touch id, only apple can supply home buttons with touch id
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
The OP may have damaged the flex cable. Even a tiny tear could cause the Touch ID to fail.
tarafından
Yorum Ekle
Yanıtını ekle
glennjacobs sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 424
