Ana içeriğe geç
2.2 GHz (Turbo Boost up to 3.4 GHz), 2.5 GHz (Turbo Boost up to 3.7 GHz), or 2.8 GHz (Turbo Boost up to 4.0 GHz) quad-core Intel Core i7 processor with 6 MB shared L3 cache.
773 Soru Tümünü görüntüle
Left I/O connector is damaged
Hello Guys,
I have a tough one for ya. I have a Logic-board 820-00138-A with a damaged I/O connector (connector A). Does anyone know If I can replace the connector with a connector B (from the I/O cable) or have a source for this part, other than buying a whole Logic-board? Both A and B connectors are the same size and each have 20 pins. I also tested the female side of the I/O cable and it does fit both A and B connectors.
tl;dr: Can I De-solder this connector from an I/O cable and reuse it, or do I have to buy another Logic board?
The Damage
Update: This connector is the worst. I managed to misplace a couple of these arch pins.
Bu iyi bir soru mu?
Puan 0
6 Yorum
Why Don't you post a pic so people can see how bad it is.
tarafından
Its nice and toasty.
tarafından
I've never micro soldered so I bet @tcrs_circuit could help you out.
tarafından
@anthonyj - You still need to figure out what caused the short and if more damage is present on the logic board.
tarafından
Anyone have a spare .brd file? ;) I'll buy it shortly.
tarafından
1 tane daha yorum göster
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
The connectors look pretty similar based on the photos. You would need to use a digital caliper to verify that they are indeed identical. Donor boards aren't usually that expensive and can offer lot's of spare parts as well so they are a great way to get parts that are difficult/impossible to source.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Anthony sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 3
Her zaman: 177
