apple hi-fi won't work on mains, it only works on batteries.
Hi, my apple hi-fi won't work on mains supply, it only works on batteries. help
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Hi @iain_sinclair ,
You will have to open the device and then check the connections from the mains power inlet to the motherboard.
Here is a link that hopefully may be of some help.
If you cannot see (or test, using a DMM- digital multimeter) what the problem is, take some close up pictures of the motherboard and perhaps someone will be able to help you further. Here's how to do that. Adding images to an existing question
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 10
Her zaman: 250
7 Yorum
Please explain. Do you mean it won't work on wall power?
Reed Crosby tarafından
yes, thats correct it won't work on wall power
Iain Sinclair tarafından
Have you tried a different outlet?
Aiden tarafından
yes tried different wall outlets and different power lead, the problem is with the apple unit.
did you drop it before? anything happen before it broke?
Aiden tarafından
2 tane daha yorum göster
