I have horizontal lines on part of my TV screen.
Hi all - Hopefully someone out there might be a little bit more helpful than the Sony Troubleshooting Guide:
Sony Bravia Model No: KDL-47W805A
Only yesterday a number of horizontal lines appeared on my TV screen, only the lower 1/3 portion of the screen though. They intermittently flicker between 1/3 of the screen having visible lines to only the top three of four lines.
I have attached two pictures below which I hope go some way to demonstrating the issue.
So far I have:
1: Switched the TV off for a period of time and then switched it back on - The lines still appear.
2: Removed all the connecting cables (Amazon, HDMI, Cable) and then switched it back on again - The lines still appear.
3: Conducted a factory reset - The lines still appear.
4: Applied pressure along the edges of the TV where the lines appear - No change, the lines are still visible, no distortion to them. Although this might seem strange I read somewhere that if there is a loose connection along the LCD connectors applying pressure might confirm this is the lines change with the application of pressure.
5: Given up :(
Bu iyi bir soru mu?
This is usually a ribbon cable that leads from the LCD to the main video board that for whatever reason has unseated some of its contacts...if you feel brave enough and think it's worth reseating the cable...make sure it's switched off from the mains...put the tv face down on a duvet or bed...remove all the rear screws and spcables and prise of rear panel....look for the main cable that comes from the LCD and trace where it connected to the video board...disconnect one end at a time and check for oxidation on the contacts...and reseat....thus usually cures thus type of problem...if it doesn't then the next likely area of cause will be the video board itself....these are modular and you can either source the exact board from eBay or source a broken screen version if the same tv..and use it for donor..bits..or chance your arm and get a quote from a tv repairer or bite the bullet and by another set..I know some the answers are pretty obvious...but I am sure you will gain more of an idea from what's been said .
john cordey tarafından
Hi did you manage to fix this I have same problem @griffalo
Mousey VR tarafından
I have the same problem.. my tv is still 1 year and 2 months
Janette tarafından
Hi @janette my tv was only 1 year and 5 months old sony bravia KD55XD7005BU I still have same problem even though I've placed the T con board
What did you do? Is there still horizontal lines present in your tv?
Janette tarafından
31 tane daha yorum göster
