Full battery but won’t turn on
My s95 camera worked well last time I used it but now won’t turn on. I have already ordered a new battery and installed it but still no go. Is there an easy check I am missing?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Ned Hascall start by checking the battery contacts as well as the battery door. If it does not make proper contact your camera will not get any power. Let us know what you get once you've replaced the battery.
Bu yanıt yardımcı oldu mu?
I am a having a similar issue and have replaced the batteries. Is their another step I can take?
@Chris Cool Did you check the battery compartment door? If it does not make proper contact it will not work
Yes I checked the door and it made contact but I was never able to get the camera working
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 13
Her zaman: 1,003
2 Yorum
I’m having the same issue with my s95. Battery door compartment is all fine but still won’t turn on. Has anyone found a solution please help a girl out :(
Christina tarafından
@christina73227 does your S95 give you any sign of life? Checked the battery, just to make sure?
oldturkey03 tarafından
