Ana içeriğe geç
The Canon PowerShot S90 is a high-end 10.0-megapixel compact digital camera originally announced in 2009.
6 Soru Tümünü görüntüle
Full battery but won’t turn on
My s95 camera worked well last time I used it but now won’t turn on. I have already ordered a new battery and installed it but still no go. Is there an easy check I am missing?
Bu iyi bir soru mu?
Puan 1
2 Yorum
I’m having the same issue with my s95. Battery door compartment is all fine but still won’t turn on. Has anyone found a solution please help a girl out :(
tarafından
@christina73227 does your S95 give you any sign of life? Checked the battery, just to make sure?
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Ned Hascall start by checking the battery contacts as well as the battery door. If it does not make proper contact your camera will not get any power. Let us know what you get once you've replaced the battery.
Bu yanıt yardımcı oldu mu?
Puan 1
3 Yorum:
I am a having a similar issue and have replaced the batteries. Is their another step I can take?
tarafından
@Chris Cool Did you check the battery compartment door? If it does not make proper contact it will not work
tarafından
Yes I checked the door and it made contact but I was never able to get the camera working
tarafından
Yorum Ekle
Yanıtını ekle
Ned Hascall sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 12
Her zaman: 1,003
